Tutorial pour enlever ou mettre les db heaters sur Akrapovic
JSWeyth
Message par JSWeyth » 13 mai 2007 04:15
(1) Standard Akrapovic fitted with Baffle.
(2) Unscrew the 3 allen bolts - Be BLOODY CAREFUL with the top bolt as it can easily fall into the exhaust if you haven't got a hold on it!
(3) Take hold of the baffle and pull to dislodge the outer fitting. If it is stiff (never been out before and greased) then a pair of pliers may be required, but put a rag on the jaws so you dont mark your Baffle.
(4) Remove the outer Baffle ring.
(5) Extract the Baffle.
(6) Exhaust with Baffle removed.
(7) Re-fix the outer ring with the three allen bolts (having greased them nicely with coppercrest). Be careful of that top bolt again!!!
1.Image 2.Image 3.Image
4.Image 5.Image 6.Image
7.Image
Be prepared for the NOISE and complaints from the neighbours.
* Baffles are a legal requirement and should only be used for 'race' purposes. Without the Baffles in you might be prosecuted by the local constabulary.
They have nothing to do with the Catalytic conversion process, they merely reduce the dBA output at the pipe, although on some machines the back pressure that they create is used to obtain the correct engine performance.
eliminator44
Message par eliminator44 » 20 avr. 2008 21:27
If you remove the db-eaters, you lose a lot of Nm. Better is to put Slac-eaters in it. Slac is a German Mt driver who produces his own eaters.
They are better eaters than the original Akra eaters.See picture below.
http://www.donnermeister.de/forum/index ... 7217;image
The original exhaust is not bad, below 2300 rpm and more than 3600 rpm its the best.
with blonds more fun
http://s121.photobucket.com/albums/o237/eliminator44
Message par SCARECROW » 20 avr. 2008 21:57
j'ai pas tout compris mais ou peut on trouver ces super DB ??
Dumè
Message par Dumè » 21 avr. 2008 05:57
[mode humour] ils font vraiment des tutoriels pour n'importe quoi!!
:lol: :lol:
c'est ce que j'ai fait des que j'ai mis les akras !!!
vouloir c'est pouvoir!
croire c'est avoir!
bye shrek....
eliminator44
Message par eliminator44 » 21 avr. 2008 19:46
Pas super, mais ils sont mieux. "Slac", un membre de Forum dÁlemagne a inventer ce db-eaters et vends ils. Le bruit nést pas mal.
www.rockslac.de voir tuning slac-eater
Message par SCARECROW » 03 mai 2008 22:04
ces un petit peu chér quand même :/ mais merci pour le renseignement à bientôt dans les vosges
Message par SCARECROW » 02 juil. 2008 12:09
ça ça marche bien aussi
TTfab
Message par TTfab » 09 sept. 2008 13:03
petite quéstion ?
les DB killers AKRA n'ont pas de fond grillagé ?
lecter.luna
Message par lecter.luna » 09 sept. 2008 15:03
Nop
TTfab
Message par TTfab » 10 sept. 2008 07:00
je comprend pas comment ils peuvent atténuer le bruit ??? :(
Message par SCARECROW » 10 sept. 2008 10:15
TTfab a écrit :je comprend pas comment ils peuvent atténuer le bruit ??? :(
ça ne l'atténue pas ça le régule je parle des miens car ceux d'origine reduise considérablement le daimétre de sortie donc moins de bruit CQFD
lecter.luna
Message par lecter.luna » 10 sept. 2008 10:25
En gros, si je me plante pas, les gaz sont bloqués autour du tuyau du Db et sont obligé de revenir vers l'arrière pour être évacué, par conséquent ils ne sortent pas directement et font moins de bruit.
Hein ? c ça ? me suis pas planté messieurs les experts ?
Clem ;)
Message par SCARECROW » 10 sept. 2008 10:30
lecter.luna a écrit :En gros, si je me plante pas, les gaz sont bloqués autour du tuyau du Db et sont obligé de revenir vers l'arrière pour être évacué, par conséquent ils ne sortent pas directement et font moins de bruit.
Clem ;)
19/20 :lol: :lol:
Message par Philip J80 » 10 sept. 2008 10:59
Pourquoi 19 , non mon ti gars c'est 20/20 .
Message par SCARECROW » 10 sept. 2008 12:27
Philip J80 a écrit :Pourquoi 19 , non mon ti gars c'est 20/20 .
la perfection n'existe pas..............................sauf moi peut-étre :lol: :lol: :lol:
